[ICEM] How can i get a best mesh quality
Old   December 4, 2009, 11:02
Default How can i get a best mesh quality
BACHIR
tgrt18 is on a distinguished road
Hello all.
I need some help about my naca0012 airfoil meshing
you can see the grid quality is very poor [picture below]
how to make it orthogonal especially near the walls?
Thanks.
tgrt18 is offline   Reply With Quote
Old   December 4, 2009, 23:34
zeitistgeld
zeitistgeld is on a distinguished road
For 2D mesh, I often use Gridgen due to it's PDE smoothing function, ICEM seems to have something like that but actually not so efficient. But you can use edge link and node spacing etc. to chang the distribution of the node on the outer edges. That might help!Below is the airfoi mesh generated in Gridgen.
zeitistgeld is offline   Reply With Quote
Old   December 11, 2009, 14:55
Default Ortho
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
There is also edge splitting to create a split on the outside of the boundary layer and align the distribution to get a more orthogonal result.
There is an orthogonal smoother in ICEM CFD that should take care of this for you.
When I finally find time to make a little movie for blocking the 2D airfoil, I will end it with steps to make them mesh orthogonal.
In my opinion, if you are not already in Gambit, heading that direction now is a bit too late.
PSYMN is offline   Reply With Quote
Old   December 11, 2009, 15:44
Rauno
Location: San Diego (USA); Pisa (Italy); Munich(Germany)
fulkrum is on a distinguished road
Such a controbution would be great!!
I found, for 2D gridding of airfoil, gridgen to be more immediate.
With ICEM I did some tutorial, I tried with different topologies, but wasn't yet able to find a satisfying solution.
If, before of the video which can take a long to be elaborated, you can quickly post the block strategy, it will be very helpfull as a starting point.
fulkrum is offline   Reply With Quote
Old   June 7, 2010, 15:48
Default 2D airfoil...
PSYMN's Avatar
Simon Pereira
Have you seen the 2D airfoil demo posted at "www.youtube.com/ansysinc/"
Simon
Old   December 30, 2014, 23:02
Alhasan's Avatar
Hasan K.J.
Alhasan is on a distinguished road
Hey Simon,
I am having a similar problem of the mesh not being orthogonal at the wall for just a simple NACA 0012 case and I am new to ICEM. I have followed your youtube tutorial, and when I fix the first cell height and apply orthogonal smoothening a lot cells close to the walls are getting mutated and looking not so good. What is the best way to get cells to orthogonal close to the wall. I have also used edge splitting to get boundary layer region around the airfoil for refinement.
Regards,
Hasan K.J
"Real knowledge is to know the extent of one's ignorance." - Confucius
Alhasan is offline   Reply With Quote
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 04:24
[snappyHexMesh] mesh quality control and fix tachyon_me OpenFOAM Meshing & Mesh Conversion 0 October 6, 2009 12:48
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
mesh quality julie FLUENT 5 July 26, 2004 05:31
