[ICEM] Merge curves
Old   March 3, 2015, 02:01
Default Merge curves
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
Dear ICEM experts,
I need some help with geometry operations. I imported a 2d geometry to ICEM from some etching mask tool. The problem is, that this geometry consists of about 65000 lines, just because circles are not imported (or exported) as circles but as zillions of single lines.
Is there any way I can just mark these lines and click some "join lines" button, to get rid of these thousands of single lines? Consecutive tools hang, when I have that many lines...
Philipp.
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
Old   March 3, 2015, 03:54
Daniel
Daniel_Khazaei will become famous soon enough
I don't know if you have already tried that but there is an option to Concatenate/Reapproximate curves in ICEM CFD under:
Geometry -->> Create/Modify curve -->> Concatenate/Reapproximate Curves
I have used this functionality for up to 4 lines but I don't think there would be any limitation on that.
Best wishes
Daniel_Khazaei is offline   Reply With Quote
Old   March 3, 2015, 05:02
Philipp
Great, that looks like what I was searching for. Thanks!
I never made the geometry with ICEM, but with Design Modeler. That's why I don't know all these tools...
Old   March 5, 2015, 02:36
Raghav
raghav is on a distinguished road
Delete all curves and points. And then use build topology with tolerance 0.05, 0.1 or 0.2 unitill you get a best topology.
raghav is offline   Reply With Quote
merge two connectors v_herw Pointwise & Gridgen 1 August 28, 2014 09:14
[ICEM] Two boxes connected by a cylinder, blocks merge where I don't want them to merge. Polarbear ANSYS Meshing & Geometry 4 April 30, 2014 15:21
[ICEM] Error 2D mesh - Separate curves seen as one when associating bbmorales ANSYS Meshing & Geometry 3 June 11, 2013 11:56
Version 7.04 : disappearing feature curves and other woes nomad STAR-CCM+ 2 September 4, 2012 21:07
about merge mesh lian Main CFD Forum 3 February 29, 2008 10:47
