[ANSYS Meshing] How to mesh this type of geometry?
Old   May 20, 2015, 15:05
Default How to mesh this type of geometry?
muhaimin
Muhey is on a distinguished road
Hi,Im still new and beginner in mesh generation. I want to ask what is the best method and step to mesh this type of geometry(Single tube and fins of car radiator). I've tried many method refer to the tutorial and so far still not success.
I'm preparing this for fluent (k-espilon model ) analysis
Height = 680mm
no of fins = 98
Muhey is offline   Reply With Quote
Old   May 21, 2015, 00:49
amin.z's Avatar
Amin
amin.z is on a distinguished road
hi.
Did you used sweep method!? maybe it help you...
amin.z is offline   Reply With Quote
Old   May 24, 2015, 04:27
muhaimin
Originally Posted by amin.z View Post
hi.
Yes..I already try with different method but i still get minimum orthogonal quality below 0.01
Old   May 25, 2015, 01:44
amin.z's Avatar
Amin
it seems sweep could help you,
anyway, you have a thin part in long length so meshing this part need many elements in length,
you should do some simplifications, otherwise you'll have a lot of tet elements!
Old   May 25, 2015, 20:09
Kapi is on a distinguished road
Hi Muhey,
As Amin explained, Slice your model and use only a small portion(few fins) to model top reduce number of Elements.
Use Sweep Method and Sizing function to get a good quality mesh.
Cheers
KAPI
Kapi is offline   Reply With Quote
Old   May 25, 2015, 22:10
muhaimin
I'm still having trouble in getting good mesh..here i upload my geometry file in .igs format..I tried doing what you all suggest but still not success.However,I'm still new and beginner in this maybe the mistake is from my part.
https://www.mediafire.com/?66ldvjlw0yo0i01
Old   May 25, 2015, 23:48
Hi Muhey,
First Slice your geometry in a way that you have only three loops of fins.
Suppress the other parts
Give sweep Method to inner body
Give Automatic method to other body
Give edge sizing on the Fin body(Select all edges) with
Element Size = 0.1 mm
Behavior = Hard
Bias = No
This mesh should give you
Orthogonal Quality of
Max = 1
Average = 0.71
Let me know if thats what you are after!
Cheers
KAPI
Old   May 26, 2015, 20:54
muhaimin
Originally Posted by Kapi View Post
Hi Muhey,
Behavior = Hard
Bias = No
Max = 1
Average = 0.71
Cheers
KAPI
Thanks kapi..i've done like u said and get the nice mesh..But when i apply for the whole geometry without slicing method,it took few hours to generate and get a few error.
Old   May 26, 2015, 21:10
Hi Muhey,
Why do you want to mesh the whole geometry if you are able to see the cooling effect, flow pattern in the sliced part of whole geometry.
whatever you get from the slice will be same for whole geometry.
If you want to mesh the whole geometry anyways make sure you have selected all the edges because even if you miss one it can cause errors and bigger elements.
Check your edge sizing and I am sure you will find and get rid of error!
Cheers
KAPI
Old   May 26, 2015, 21:20
muhaimin
I want the whole geometry because im investigating the temperature change with respect to the length of the tube..Anyway,i'll try to check again but just doing for the slice part is still good idea to proceed..Thank you very much for your help..
ansys meshing, fluent
inlet pressure is higher than outlet pressure for fan sivakumar OpenFOAM Pre-Processing 16 December 30, 2017 14:16
Problem with geometry - concentric cylinders Rhoddwen OpenFOAM Running, Solving & CFD 0 December 15, 2014 09:22
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
Pressure instability with rhoSimpleFoam daniel_mills OpenFOAM Running, Solving & CFD 44 February 17, 2011 17:08
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
