[ICEM] Blocking - Set mesh law across all parallel edges |
August 12, 2015, 07:18 |
Rep Power: 13 |
Is there a way in ICEM 14.0 (have access to 15.0 or 16.1 also) to copy just the meshing law across all parallel edges without changing the spacing? Thanks, Matt |
August 12, 2015, 10:00 |
Javi
Rep Power: 16 |
You have this option inside Edge Param as Copy Parameters and using To All Parallel Edges option.
August 12, 2015, 10:08 |
Rep Power: 13 |
But this also copies the initial spacing to the other parallel edges.
What I want is to change all parallel edges from hyperbolic to bi-exponential (for instance) without also copying the spacing across. |
August 12, 2015, 10:34 |
Javi
Rep Power: 16 |
I am not hundred per cent sure, but I think you can't do it.
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
simpleFoam parallel solver & Fluent polyhedral mesh | Zlatko | OpenFOAM Running, Solving & CFD | 3 | September 26, 2014 06:53 |
[snappyHexMesh] determining displacement for added points | CFDnewbie147 | OpenFOAM Meshing & Mesh Conversion | 1 | October 22, 2013 09:53 |
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation | tommymoose | ANSYS Meshing & Geometry | 48 | April 15, 2013 04:24 |
gambit: mesh edges, change direction | Ralf Schmidt | FLUENT | 2 | August 29, 2006 10:55 |
