August 31, 2015, 23:22 |
meshing 2d VAWT
abuabdellah
Rep Power: 13 |
i am sorry, but i am new
and i do not know if this is the right place to post that or not i am working on 2d VAWT i used the workbench meshing but i think it doesn't go right because of the mesh ... can i mesh like this in workbench meshing ? 2015-09-01_5-12-28.jpg 2015-09-01_5-13-15.jpg if not where i can do mesh like that in ansys products ? thanks in advance ... best regards ... |
September 2, 2015, 05:31 |
ideas guys!!!!
abuabdellah
Rep Power: 13 |
ideas guys!!!!
September 3, 2015, 03:38 |
Amin
Rep Power: 14 |
yeah, Ansys meshing is able to generate a mesh similar to these photos,
you need to divide your domain and use inflation |
September 3, 2015, 08:52 |
abuabdellah
Rep Power: 13 |
i do it, but the element not triangular !!
September 3, 2015, 09:07 |
Amin
Rep Power: 14 |
Select the body, then right click and select method, eventually use triangle or patch conforming as method
September 3, 2015, 09:43 |
abuabdellah
Rep Power: 13 |
sorry.. but where i should right click ?
September 3, 2015, 11:28 |
Amin
Rep Power: 14 |
in the graphic window select the body which you want apply triangle mesh on it the right click+inset+method
September 3, 2015, 12:20 |
abuabdellah
Rep Power: 13 |
thanks alot !!!
i found it .... but one question si there is a big influence on the solution from quadlateral and triangles ? |
September 3, 2015, 13:17 |
#9 |
Amin
Rep Power: 14 |
it depends on the accurate that you prefer, if it's so important for you, maybe it's better to use a structure mesh, if not use triangle,
if you generate a high quality triangle mesh, I guess it will be satisfactory... |
[Gmsh] Vertex numbering is dense | KateEisenhower | OpenFOAM Meshing & Mesh Conversion | 7 | August 3, 2015 10:49 |
2D vawt simulation meshing and fluent error | daysley | FLUENT | 5 | April 15, 2014 19:51 |
[GAMBIT] VAWT 3D meshing in Gambit | nana | ANSYS Meshing & Geometry | 1 | January 16, 2013 10:12 |
[ANSYS Meshing] Meshing a 3d VAWT | Rudysa2 | ANSYS Meshing & Geometry | 2 | February 28, 2011 22:58 |
