[GAMBIT] Copying the edge
Like Tree4Likes
  • 1 Post By -mAx-
  • 1 Post By -mAx-
  • 1 Post By -mAx-
  • 1 Post By -mAx-
Old   September 16, 2015, 15:23
Default Copying the edge
Aja
aja1345 is on a distinguished road
Hi dear friends,
According the following link(dbs file of Gambit), I want to copy the edge.146 relative to edge.147, But I can't do this work.
http://www.4shared.com/file/Uck5KFnIce/max.html
I am grateful that guide me about this case.
Thanks,
Best,
Aja
aja1345 is offline   Reply With Quote
Old   September 17, 2015, 04:07
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
don't mix move and copy
I assume you moved the edge, but it is not possible since vertex 210 bvelong to another entity (surface.1)
So in your case you need to copy
aja1345 likes this.
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   September 17, 2015, 06:09
Aja
Yes,
But How to copy?
I dont know how I copy the edge.146 relative to edge.147.
Should i use option of Reflect? but How?
Thanks,
Old   September 17, 2015, 06:14
-mAx-'s Avatar
Maxime Perelli
https://www.sharcnet.ca/Software/Gam..._edge_movecopy
instead of move, select copy
aja1345 likes this.
Old   September 17, 2015, 07:15
Aja
I should use the reflect option in this case, But How?
I studied Gambit help but it is not explained in this case well.
Old   September 17, 2015, 07:21
-mAx-'s Avatar
Maxime Perelli
explain what do you want to do exactly
aja1345 likes this.
Old   September 17, 2015, 09:51
Aja
Thanks,
According the following figure, I want create red edge (similar to edge.148) by means of copy option. but I dont know how I do.
I think that this work is done by means of reflect option, of course, using edge.147 .
Now, What is your opinion?
Old   September 18, 2015, 01:56
-mAx-'s Avatar
Maxime Perelli
ok now it is clear
so you need to reflect the edge (but use copy option, not move).
choose the right vector definition, in your case y<0)
You will see the edge will be reflected but in respect of the original coordinate system.
The you have to move (not copy) the copied edge to the place it should be (you need to create a vertex).
But the easier way in your case is to move all your domain, in such way that your airfoil will be centered to the coordinate system.
So:
*move all faces (0 -0.5 0) with option "connected geometry"
*copy desired edge with reflect and vector (0 -1 0)
*move all faces (0 0.5 0) with option "connected geometry"
*finally move the edge you reflected with translation and vector (0 0.5 0)
aja1345 likes this.
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
Actuator disk model audrich FLUENT 0 September 21, 2009 07:06
Where's the singularity/mesh flaw? audrich FLUENT 3 August 4, 2009 01:07
[Commercial meshers] Star mesh import problem chris1980 OpenFOAM Meshing & Mesh Conversion 20 May 8, 2006 01:07
