[DesignModeler] How to build 3D curve from manually input construction points? |
October 4, 2015, 03:35 |
Claire Gong
Hi, I am trying to optimize some curved geometry from 4 points with 3d coordinates as design parameters. So I created points by Manually input method, but failed to select these points in a 3D curve creation (under<Concept).
Was it because that the Manually input construction points are not opt for selection? If the points are not for selection to build a curve, what are they used for? Are there other ways to build 3d curve from controllable points whose coordinates will be the design parameters? I am quite new to Ansys, pls help~ Last edited by aprilgng; October 5, 2015 at 13:55. |
October 5, 2015, 13:56 |
Claire Gong
Have anyone done something similar, or used the points coordinates as parameters before?
Pls help~ |
[ICEM] Smoothing a curve | lost.identity | ANSYS Meshing & Geometry | 6 | July 13, 2009 05:23 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
Text input commands to add data points | Kathryn | FLUENT | 0 | November 5, 2007 17:38 |
Normal to Line - Curve Equ. from Points | A.S. | Main CFD Forum | 5 | July 5, 2005 02:41 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
