December 12, 2015, 02:09 |
high aspect ratio ICEM
Mahmoud
Rep Power: 11 |
hi, everyone
i have this problem on all ICEM meshing ... high aspect ratio .. if i increase the number of nodes , my laptop hang up ... thanks advanced to every one https://imgur.com/4fU88sL |
December 16, 2015, 09:11 |
Maxim
Rep Power: 12 |
maybe double check your blocking... I once had some cells with bad aspect ratios and then noticed that I had forgot to delete a block outside of my flow field. ICEM tried to put some weird cells there. After fixing that, everything was fine.
you can also adjust the numbers of bars/ the scale of the axis in order to show the cells with the bad ratio (click on the bad column). Last edited by -Maxim-; December 16, 2015 at 09:14. Reason: asdf |
[Other] checkMesh error (High aspect ratio cells found) | Alih | OpenFOAM Meshing & Mesh Conversion | 1 | August 9, 2014 09:33 |
[ICEM] ICEM Cfd Aspect Ratio | mpalacz_sut | ANSYS Meshing & Geometry | 3 | April 19, 2013 15:10 |
[ANSYS Meshing] High aspect ratio | Roby_1986 | ANSYS Meshing & Geometry | 0 | February 22, 2013 05:34 |
Automobile aero ground boundary layer OR simpleFoam/GAMG and high aspect ratio cells | kyle | OpenFOAM Running, Solving & CFD | 4 | January 4, 2011 11:17 |
Help Needed: High aspect ratio | Michelle | FLUENT | 0 | January 24, 2003 03:15 |
