[DesignModeler] Importing a 2D sketch into design modeler and meshing
Old   January 11, 2016, 11:14
Default Importing a 2D sketch into design modeler and meshing
Kevin Williams
firestone9x is on a distinguished road
I want to perform a 2D analysis on a 3D airfoil I have created using Inventor.
Using design modeler, I created a mid-surface and moved on to meshing. When generating a mesh, it shows as 3D...
Is there any workaround the current issue I have or is there any other method of importing a 2D sketch into the design modeler.
Note: I have also tried .dwg but it results with an error stating "the selected file is of an unsupported or unconfigured geometry type"
Please help me with this issue.
Thanks.
firestone9x is offline   Reply With Quote
Old   January 13, 2016, 09:45
hwet is on a distinguished road
make the geometry again in 2d
hwet is offline   Reply With Quote
Old   January 14, 2016, 04:13
Kevin Williams
Thanks for the reply.
I did create a 2D sketch of the geometry in Inventor and saved it as .dwg as I mentioned earlier, which resulted in an error.
Are you suggesting to create a 2D sketch in the design modeler?
The reason I am doing it on a CAD package is because it has complex curves and modifications to the sketch are quicker.
Old   January 14, 2016, 05:17
Gweher's Avatar
Gwenael H.
Gweher will become famous soon enough
The problem is that you can't import a 3D geometry and then perform a 2d analysis. For a 2D analysis you need to specify it in the project properties before importing the geometry (under "Advanced Geometry Options > Analysis Type > 2D").
I often recreate easy geometry directly in DM but if you have more complex curves with mathematical formulas it is way better to import them directly in DM. So the easiest way is to create a mid surface in Inventor, then import it in DM as 2D. Here you also need to pay attention to the sketching plane, for 2D analysis in Ansys you need to be in the XY plane otherwise you'll end up with an error.
Have fun
Gweher is offline   Reply With Quote
Old   January 14, 2016, 05:24
not sure what sort of files can be imported into workbench from a CAD package. make sure ansys can read dwg format first.
Old   January 14, 2016, 05:35
Gweher's Avatar
Gwenael H.
Yes it can, there are a lot of formats supported by DM:
  • ACIS (*.sat, *.sab)
  • AutoCAD (*.dwg, *.dxf)
  • BladeGen (.bgd)
  • CATIA (*.model, *.exp, *.session, *.dlv, *.CATPart, *.CATProduct)
  • Creo Elements/Direct Modeling (*.pkg, *.bdl, *.ses, *.sda, *.sdp, *.sdac, *.sdpc)
  • Creo Parametric (*.prt, *.asm)
  • GAMBIT (*.dbs)
  • IGES (*.igs, *.iges)
  • Autodesk Inventor (*.ipt, *.iam)
  • JT Reader (*.jt)
  • Monte Carlo N-Particle (*.mcnp)
  • NX (*.prt)
  • Parasolid (*.x_t, *.xmt_txt, *.x_b, *.xmt_bin)
  • Solid Edge (*.par, *.asm, *.psm, *.pwd)
  • SolidWorks (*.sldprt, *.sldasm)
  • SpaceClaim (*.scdoc)
  • STEP (*.stp, *.step)
And if you have license issue then you should pass through an neutral file format as a parasolid or .igs /.stp
Old   January 15, 2016, 05:17
Kevin Williams
Have fun
Thank You Gweher. Your method worked. Really appreciate the help.
So I removed the extrusion from my model leaving only the 2D Sketch. I then created a surface and saved it as a 'Step' file.
I then imported it into the design modeler as 2D and it worked successfully.
Note: I also copied the sketch to the XY plane which resolved the errors in the meshing part. It doesn't work in any other plane like you mentioned earlier.
Old   January 15, 2016, 08:01
Gweher's Avatar
Gwenael H.
Thanks for your feedback, and happy that my inputs helped you to solve your problem.
Old   January 20, 2016, 12:27
Default Problem in getting periodic boundary conditions
SHERIN S B
SHERIN SHARAF is on a distinguished road
Can anybody help me ??? I am trying to simulate a simple geometry in ANSYS WORKBENCH and i have to give periodic boundary condition to it . But the same is not taking it as periodic boundary condition !!! when imported in FLUENT it is giving error message as "Failed to make zones periodic"
SHERIN SHARAF is offline   Reply With Quote
Old   June 17, 2017, 05:17
aer
Julia
aer is on a distinguished road
is the number of mesh node on periodic boundary are equal?
aer is offline   Reply With Quote
Old   July 28, 2017, 06:33
Default import Autocad geometry to Ansys Workbench with proof
  #11
optimus prime is on a distinguished road
https://www.youtube.com/watch?v=-Y1NWiZbbZY
https://www.youtube.com/watch?v=Y8VtWAXL5-U
optimus prime is offline   Reply With Quote
Old   September 30, 2017, 01:32
Cyrus
BigCatDairy is on a distinguished road
Send a message via Skype™ to BigCatDairy
thanks
BigCatDairy is offline   Reply With Quote
[Other] Connecting 3D bodies in Ansys Design Modeler chipper ANSYS Meshing & Geometry 4 January 25, 2018 09:45
How to make appear edge/line body (created in design modeler) in the meshing tool Rockda ANSYS Meshing & Geometry 6 June 8, 2016 23:10
[DesignModeler] Boundary Layer Meshing in Design Modeler ansab_sindhu ANSYS Meshing & Geometry 0 October 12, 2015 15:01
[Other] [DM] Meshing with Design Modeler TxoniMoni ANSYS Meshing & Geometry 2 May 20, 2010 14:35
Design Modeler to ICEM..... Joe CFX 0 January 24, 2008 03:39
