Using the CMD line to control ICEM
Old   February 1, 2016, 09:48
Default Using the CMD line to control ICEM
Sean Loveridge
SeanLFCDF is on a distinguished road
As part of my degree I am currently creating a matlab structure to control both ICEM and FLUENT. I know that it is possible to control FLUENT, as I can make CMD read a journal file. However, while it is possible to launch ICEM from the CMD line, it is unclear whether I can then make it read a replay script. Does anyone know whether this is possible, and if so, how?
SeanLFCDF is offline   Reply With Quote
Old   February 2, 2016, 04:12
Michael Shives
mrshives is on a distinguished road
If you want to do automatic generation of simple meshes, I may have an alternative solution for you. I use Matlab directly to generate .cfx5 meshes. I'm not sure exactly of the fluent format, however. You could modify my core code to do more complex geometries. Let me know if you're interested.
I think you must be able to run a journal file in ICEM. Pretty sure ICEM was all command line "back in the day." (sorry I know that's not actually helpful)
mrshives is offline   Reply With Quote
Old   February 3, 2016, 07:50
Sebastian Engel
bluebase will become famous soon enough
Hi Sean,
yes, it is possible to lanch ICEM in batch and run a script file.
This is simply done by running ICEM with the following arguments:
/pathto/icemcfd -batch -script replayscript.tcl
With regards,
Sebastian
bluebase is offline   Reply With Quote
[Gmsh] 3D Mesh conversion from gmsh-2.5.0 to OpenFOAM Ancioi OpenFOAM Meshing & Mesh Conversion 17 January 8, 2019 23:50
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' muth OpenFOAM Running, Solving & CFD 3 August 27, 2018 04:18
Derivative of velocity and mean velocity hiuluom OpenFOAM Post-Processing 1 May 29, 2015 23:42
Problem of compilation OF 14Allwmake command not found erik_d OpenFOAM Bugs 13 September 13, 2008 21:45
Problems of Duns Codes! Martin J Main CFD Forum 8 August 14, 2003 23:19
