[ANSYS Meshing] Tubes Mesh(Cylindrical) in Heat Exchanger |
March 2, 2016, 16:56 |
Onur Özcan
Rep Power: 12 |
Hi all,
I am working on 3d heat exchanger in order to view heat transfer and flow you know that mesh is the most important to evaluate the results. I have tried a variety of types of mesh but some values are awful like skewness Attached photos show mesh ( only inflation) .First one shows mapped face meshing in symmetry plane.The other one is inflated in inflation mesh Is there any methods you suggest? Kind Regards, |
March 3, 2016, 12:16 |
#2 | |
March 3, 2016, 12:24 |
Onur Özcan
Rep Power: 12 |
March 3, 2016, 19:58 |
Rep Power: 13 |
you can actually see the cells where the skewness is terrible, then decide what to do to improve it.
March 3, 2016, 20:08 |
Rep Power: 14 |
check whr you have high skewness and apply sizing thr.
try to make fine mesh at critical points and regions with high skewness! |
March 5, 2016, 04:40 |
Number Of Elements
#6 | |
Hamed
Rep Power: 13 |
I am working on a flow in shell side of a heat exchanger and it has bout 240 tubes and 5m length so I can`t mesh it because when I use inflation method it has maybe about 110,000,000 elements.How can I reduce it? |
March 5, 2016, 05:58 |
#7 | |
Onur Özcan
Rep Power: 12 |
sizing thr ?, what does it stand for ''thr'' ? Please could you see the photos last mesh situation in attached? I have used inflation and mapped mesh rather than using sweep or multizone ( because there are 28 tubes and I dont know how can I mesh all tubes in multizone and sweep) ELEMENT : approximately 8 millions NODES : approximately 3 millions Skewness shows that in that attached photo is 0.96 bla bla bla but now 0.9503 bla bla Kind Regards, |
March 5, 2016, 08:52 |
Onur Özcan
Rep Power: 12 |
what should max skewness be ? 0.89 ? I have decreased it at most 0.949995 bla bla .
March 6, 2016, 16:20 |
#9 |
Rep Power: 14 |
sometime going to help section and looking for answer is better!!
From Ansys help: The following table lists the range of skewness values and the corresponding cell quality. Value of Skewness Cell Quality 1 degenerate 0.9 <1 bad (sliver) 0.75 0.9 poor 0.5 0.75 fair 0.25 0.5 good >0 0.25 excellent 0 equilateral According to the definition of skewness, a value of 0 indicates an equilateral cell (best) and a value of 1 indicates a completely degenerate cell (worst). Degenerate cells (slivers) are characterized by nodes that are nearly coplanar (collinear in 2D). Highly skewed faces and cells are unacceptable because the equations being solved assume that the cells are relatively equilateral/equiangular. Hope it helps. Also, try to make your model smaller. Either mirror it or use a sample model to see the effects. Cheers KAPI |
Heat Exchanger Model | sak2129 | FLUENT | 3 | September 26, 2017 01:29 |
Solidwork flow floefd - modeling heat exchanger in a system | mzreik | FloEFD, FloWorks & FloTHERM | 3 | January 8, 2016 11:30 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
Macro Heat Exchanger not selecting (Please help!) | zdeth | FLUENT | 2 | September 11, 2012 13:52 |
UDF for Heat Exchanger model | francois louw | FLUENT | 2 | July 16, 2010 02:21 |
