[GAMBIT] Meshing & Exporting a Domain of Different Sub-Volumes
Old   May 31, 2009, 19:12
Default Meshing & Exporting a Domain of Different Sub-Volumes
Stamatis is on a distinguished road
Hello everyone,
As I said in a previous post I am working on modelling cooling of a ventilated disc brake.
I have taken a 12 degree repeating sector of the geometry which I intend to model using a rotating frame of reference.
My problem is that although I have subdivided the original geometry (imported as a step file) into various subvolumes, as you can see in my first attachment, and have managed to mesh it (poorly I know, but I am just trying for now), as you can see in my second attachment,
when I try to export it it is OK but when I import into CFX I get a reading error saying something like "premature file end".
I read somewhere that I need to link the face meshes of something to be able to have a .msh file that can be read. I really don't know what this means or how to do it.
Could someone PLEASE spare a few moments to lay down a few steps I need to follow when subdividing a volume (in case I am making a mistake there) and when meshing the separate volumes, as I don't know if I am missing a step out or if I am doing something totally wrong and messing up the .msh file.
Have a look at my attachments, it is quite critical that I manage to import to CFX soon.
Thanks in advance and I hope I can get some help.
Stamatis is offline   Reply With Quote
Old   March 28, 2016, 08:15
Smile
Nazim
shahid nadeem is on a distinguished road
Hello did you go the reason for this and had you clarified
Thank You
shahid nadeem is offline   Reply With Quote
Old   March 29, 2016, 01:13
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
If you want to use "periodic" boundary condition, you will have to link face meshes which have been selected for the periodicity.
Doing that you will have exactly same surface meshes for the periodicity
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Meshing around domain interface Tom S CFX 0 August 1, 2008 05:31
meshing 3 connected volumes with gambit Miguel FLUENT 1 July 20, 2006 05:50
Help with splitting volumes and meshing Vidya Raja FLUENT 5 May 27, 2006 14:17
Meshing two volumes Vidya Raja FLUENT 1 October 5, 2005 02:46
Meshing of split volumes Dhananjay FLUENT 3 May 28, 2002 06:09
