June 22, 2016, 19:26 |
Meshing: Nodes not on plane
J
Rep Power: 10 |
Hi all,
I am running a simulation in CFX with a symmetry boundary condition on a side. The first mesh I created worked fine - no problems. However, as soon as I make the mesh finer, I get errors with the symmetry boundary condition. It turns out one or more nodes are not directly on the face ie not parallel, and therefore the symmetry boundary condition cannot be applied. I have tried increasing the vector parallel tolerance up to 5 degrees - no luck. I can identify where the problem nodes are, but I have no idea what is causing this to happen. My questions are as follows: 1) Why does this happen when I have a finer mesh? 2) How can I fix this in ANSYS mesher? Thank you all in advance. |
Plane stress and plane strain cases for stress analysis | Sargam05 | OpenFOAM | 0 | May 3, 2013 18:16 |
[ANSYS Meshing] ICEM Meshing :specified nodes along curve did not appear | syler3321 | ANSYS Meshing & Geometry | 3 | June 13, 2012 15:45 |
[ICEM] Flow channel meshing problems | StefanG | ANSYS Meshing & Geometry | 19 | May 15, 2012 06:44 |
Scale-Up Study in Parallel Processing with OpenFoam | sahm | OpenFOAM | 10 | April 26, 2010 17:37 |
