[ANSYS Meshing] Problem ANSYS_MESHING
Old   June 29, 2016, 05:57
Default Problem ANSYS_MESHING
mehdi
mehdi2 is on a distinguished road
I m working in reactor which is a trancated cone .I did this geometry in design Modeler, and now I try to do a structed meshing in ANSYSMESHING.In fact I have ,at first, to define tow inlets (tow sufacies) ''entree1'' and entree 2 .For this ,I use intersection between different part in the bottom of the trancated cone in order to defines these inlets ,and after that I use some booleens to unit some bodies.But in the ANSYSMESHING I have some places where it is not a structed mesh.
Thanks
File Type: jpg 13569916_1717624371795656_1747372184_o.jpg (163.4 KB, 19 views)
mehdi2 is offline   Reply With Quote
Old   June 29, 2016, 09:00
Paritosh Vasava
vasava will become famous soon enough
If you want to have hexahedral mesh then you can include 'method' and then select 'Hex Dominant'. This should force ansys meshing to include hexahedral mesh elements as much as possible.
vasava is offline   Reply With Quote
Old   June 29, 2016, 10:10
mehdi
I have fixed the non structed mesh,but now I have some places in the geometry which is not mapped , I tried to use 'Face Meshing' but I didn't succeed I get message text told me that the selective body meshing is not being recorded,so the meshing may nt be persistent on an update .And finally I have something represinting in this picture.
Old   June 30, 2016, 19:04
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
This has been discussed before try to google search in the forum... consider ICEM. tutorials are available in youtube, you can mesh this faster
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
