[ANSYS Meshing] Meshing problem for transient analysis
Old   July 5, 2016, 10:37
Default Meshing problem for transient analysis
Arun subramanian
arun1994 is on a distinguished road
I am trying to make transient analysis for a simplified piston model with single intake and single outlet. I have shown it in picture 1 .
I have a problem with "negative volume " . I know my mesh is very bad . The surface mesh is pretty good to look from outside but inside using section plane ,it looks very bad as in pic 2.
How do I make a hexagonal mesh which are same in size ? Is it possible that I can "extrude " mesh from the base till the top ?
What are best practices to make hexa mesh ?
Also is there a comprehensive tutorial/PDF to read for transient analysis ?
Probably there are a lot of posts on this but I have less time now to search all. It will be nice to get specific answer for my problem.
Cheers,
Arun
arun1994 is offline   Reply With Quote
cfx, hex dominant method, ic engine, transient analysis
[ANSYS Meshing] Problem with meshing a complex Geometry (Hex) fluent_beiyo ANSYS Meshing & Geometry 8 April 26, 2014 04:55
[ICEM] Problem with meshing half NACA0009 in 3D Eizo ANSYS Meshing & Geometry 30 February 17, 2013 02:40
[snappyHexMesh] snappyHexMesh: problem meshing baffle (surface with zero thickness) julien.decharentenay OpenFOAM Meshing & Mesh Conversion 7 June 16, 2012 08:12
Problem, analysis (ansys 13 and 14) castaway ANSYS 0 June 13, 2012 05:54
problem meshing with low y+ cesco FLUENT 8 February 23, 2009 05:12
