[ANSYS Meshing] Build Grid: Aborted due to critical error |
August 5, 2016, 01:44 |
松本貴大
Rep Power: 9 |
Hi, All.
I made mesh by ICEM and I export mesh file for the ANSYS Fluent. But when I am importing the ANSYS Fluent, the error (Build Grid: Aborted due to critical error) occurs. I cant understand what is it cause. I already did the following matters 1. to change to smoothing times. Addition to write Fluent error code -------------------------------------------------------------------- > Reading "E:\ANSYSICEM(E)\fluent.msh"... 158300 nodes. 156816 quadrilateral cells, zone 9. 312147 2D interior faces, zone 10. 1188 2D wall faces, zone 11. Warning: Invalid face type 1. Skipping. Building... mesh Cell is missing face: Cell 0, zone 9, at location (-1.83172e+01, -1.91596e+01). Clearing partially read grid. Error: Build Grid: Aborted due to critical error. Error: Build Grid: Aborted due to critical error. Error Object: #f ---------------------------------------------------------------- Please, give me advice. I attache file which is blocking file. Thank you. |
error compiling modified applications | yvyan | OpenFOAM Programming & Development | 21 | March 1, 2016 04:53 |
Mesquite - Adaptive mesh refinement / coarsening? | philippose | OpenFOAM Running, Solving & CFD | 94 | January 27, 2016 09:40 |
Compile problem | ivanyao | OpenFOAM Running, Solving & CFD | 1 | October 12, 2012 09:31 |
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) | Yogini | Fluent UDF and Scheme Programming | 7 | October 3, 2012 07:24 |
error while compiling the USER Sub routine | CFD user | CFX | 3 | November 25, 2002 15:16 |
