August 5, 2016, 03:15 |
"Tension only" springs
Rep Power: 10 |
Hi everyone,
I would like to simulate the action of wires in my model thanks to springs but I cannot find how to use them "tension only" (no reaction force when compressed). Unfortunately I was not able to find a proper solution with springs after many researchs, but maybe there could also be a different way to do so. Thank you in advance for your precious help. |
August 5, 2016, 05:17 |
Stuart
Rep Power: 25 |
Assuming use are using ANSYS Mechanical you could define a spring using tabular data and set the compression side to zero, see the test in the image. If you have beta features turned on then the a tension only spring behavior is available, but as it is a beta feature the User Guide does not say is it for use (apart from explicit dynamics and RBD). I just use the tabular data for my springs.
August 5, 2016, 06:02 |
Rep Power: 10 |
You cannot be more precise, this is exactly what I was looking for.
Many thanks for your quick and efficient answer. |
Add springs to brake pads | am635 | ANSYS | 0 | April 18, 2015 13:34 |
Difficuty with springs and ropes | tms120 | FLOW-3D | 0 | January 2, 2015 11:06 |
Using springs | amol wayse | STAR-CCM+ | 3 | October 27, 2012 17:54 |
