[ICEM] learning tetra/prism meshing
Old   September 20, 2016, 09:32
Default learning tetra/prism meshing
jumpmonkey is on a distinguished road
Hi everybody,
I've recently learnt multi-block hexa, now I am trying to teach myself tetra/prism...
When I say tetra/prism... i mean the whole "set up mesh parameters => compute, check, smooth etc..." process.
Is there an umbrella term that describes all meshes generated this way?
tetra/prism dosen't fit since the final mesh can have hexa-core and pyramids...? (i'm thinking unstructured auto meshing??)
I am feeling overwhelmed by the number of options and schemes available...
So I am considering focusing only on:
shell mesh: patch dependent, independent
volume mesh: octree, Delaunay
(and worry about prism layers, hexacores, and other algorithms later)
Is this approach okay? I've chosen only these, because these seem to be the most commonly mentioned in the forum. Any other general advice is also welcomed.
thank you
jumpmonkey is offline   Reply With Quote
[ANSYS Meshing] only automatic meshing works, kazra ANSYS Meshing & Geometry 2 February 23, 2017 11:38
[Gmsh] 3D coil mesh: can't create the volume? RomainBou OpenFOAM Meshing & Mesh Conversion 3 July 18, 2016 05:09
Learning Dynamic Meshing SKDinfinity Fluent UDF and Scheme Programming 2 June 11, 2016 06:43
[Gmsh] Vertex numbering is dense KateEisenhower OpenFOAM Meshing & Mesh Conversion 7 August 3, 2015 10:49
