[GAMBIT] import terrain geometry
Old   April 4, 2009, 21:44
Default import terrain geometry
cfdworker is on a distinguished road
Hello, I have a problem that involves import terrain geometry in gambit. I have a xyz file that gives the coordinates of the points that defines the geometry of terrain, and I can do the mesh of those points to define the geometry, with terraincad. But when I try to import this geometry, gambit can’t recognize the entities. So I try to create a surface with that mesh with rhinoceros, but I can’t do a surface that is similar to the terrain. So I want to ask you if are a way to do a geometry of the terrain for gambit from the xyz file.
Sorry for my bad English.
cfdworker is offline   Reply With Quote
Old   April 5, 2009, 03:02
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
What kind of entity are you trying to import?
Surface/Volume?
I assume that gambit will just import the points, and you have to create the surface from point.
Try to use this functionality:
http://web.njit.edu/topics/Prog_Lang...e_create_vrows
Hope it helps
-mAx- is offline   Reply With Quote
Old   May 24, 2009, 21:40
Unhappy
oherreraz is on a distinguished road
I have the same problem. Becouse I dont know how is posible make a Surface with points..In gambit is not easy , and , the problem I think that is becouse , the program take all the points following the numbers , the position in the list that they have....Exist any possibility to introduce that points in Gambit and make a real surface ?, without errors, may last time , making that , was very bad...
Bis Bald
oherreraz is offline   Reply With Quote
Import geometry from CAD Giuseppe (Giuseppe) OpenFOAM Pre-Processing 34 December 14, 2017 16:24
Mesh and geometry import in cfx-pre Francesco CFX 7 May 30, 2012 08:04
import catia geometry in icem v10 anorky Main CFD Forum 4 December 26, 2009 01:15
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
vitual _ real deneb FLUENT 3 January 22, 2007 04:31
