[Sponsors] | |||||
chris
Rep Power: 6 ![]() |
Hello everyone
I have problem to obtain the mesh model for this surface: http://www.polne.net/AD/pipe_wall.jpg http://www.polne.net/AD/pipe_wall2.jpg This object is a pipe wall treated as a boundary layer for the fluid region. On the photos we can observe fluid region (red) and the another region (structure). I have introduced: - default face spacing: option-angular resolution, angular resolution-18 degrees, min edge length-0.1 mm, max edge length-4.5 mm, radius of influence-0mm, expansion factor-1.2 - inflated boundary option: number of layers-5, expansion factor-1.2, number of spreading iteration-0, min internal angle-2.5 degrees, max external angle-10 degrees, option-first layer thikness, define first layer by-first prism height, first prism height-0.01 mm, extended layer growth-yes, layer by layer smoothing-no. The length of the model is 50 mm, and the width is 25 mm. I have problem to obtain mesh due to: - boundary edge does not exit face (Subr: cutlist), - mesh spacing does not adequately resolve CAD face and results in self-intersecting boundary edges, - parameterization of faces poor near singular points. Any ideas how to mesh it ?? regards nasdak |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| mesh from icem cfd to cfx, how? | Rogerio Fernandes Brito | CFX | 15 | August 27, 2011 15:05 |
| Arbitary Surface in CFX Postprocessor | MiXaNiK | CFX | 0 | May 29, 2009 08:33 |
| CFX mesh cause software blocked | ahlo | CFX | 3 | December 13, 2007 13:34 |
| Mesh conjunction in CFX | Twiti | CFX | 4 | January 10, 2005 20:35 |
| CFX 5.6 mesh build | shhe | CFX | 1 | February 13, 2004 04:27 |
