October 1, 2011, 13:58 |
Import Geometry Dimensions
Febin
Rep Power: 14 |
I am trying to find the Coefficient of lift and drag of a UAV. The UAV was designed in Ansys Classic version. Now, when I imported the geometry into Ansys Designmodeler, the dimensions are found to be too small. For e.g, the length of fuselage was set as 1.81m while creating the model. But, in designmodeler, it is just .0475m. How do I keep the original dimensions? Thanks!!! |
October 2, 2011, 22:30 |
Just scale it...
Simon Pereira
Rep Power: 47 |
This could be some sort of units mismatch... I divided one by other expecting it to fall out as some common number like 25.4 (mm/inch). Instead it was 38.1, so I am not sure if you just were not specific enough about what had become what...
But either way, the solution is just to scale the model after it is in DM... Find the exact ratio between the models and scale it appropriately... I think the option is under the create tab, but just check the help for "scale" and do what ever factor you need to get the job done.
----------------------------------------- Please help guide development at ANSYS by filling in these surveys Public ANSYS ICEM CFD Users Survey This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)... CFD Online Users Survey |
October 4, 2011, 14:35 |
Febin
Rep Power: 14 |
Thank you Simon. As you said, scaling was what needed to be done!!!
Import geometry from CAD | Giuseppe (Giuseppe) | OpenFOAM Pre-Processing | 34 | December 14, 2017 16:24 |
Access dimensions of model geometry | cp_jef | Fluent UDF and Scheme Programming | 2 | August 1, 2011 01:11 |
Import Geometry Gambit | Henri79 | ANSYS Meshing & Geometry | 0 | May 7, 2010 02:44 |
vitual _ real | deneb | FLUENT | 3 | January 22, 2007 04:31 |
Multiple import of Geometry in GAMBIT(Catcon Simu) | Amod kumar | FLUENT | 0 | July 21, 2006 23:55 |
