How can i read mesh files made with ICEM? I want use them for my own code
Old   September 12, 2009, 10:28
Default How can i read mesh files made with ICEM? I want use them for my own code
Zoltán Hercz
zmester is on a distinguished road
Hi
Theres 2 type of mesh files in ICEM CFD as i know. .uns for unstructured, .domain for structured grids. I want to open them for my cfd code but i cant. I get with notepad a text with stange charachters. Until i cant read them, i do not able to interpret them. Is there anyone who know how to open them, or one who know the structure of these files?
(Not only the domain file belongs to the structured grid but a .blk file that i can read, but i also cannot interpret them)
Thanks for your respond!
zmester is offline   Reply With Quote
Old   September 12, 2009, 12:03
Ludvik is on a distinguished road
http://www.ansys.com/products/icemcf...cemcfd-fpl.asp
Ludvik is offline   Reply With Quote
Old   September 12, 2009, 14:04
Zoltán Hercz
Thanks! Its quite an extensive description. I hope i have patience to find out their structure.
Old   September 14, 2009, 09:15
Default ASCII vs. Binary
PSYMN's Avatar
Simon Pereira
Those links only include info for the Tetin file, blocking file, etc. These are all ASCII files and can be read with a text browser.
In Zoltan is asking about mesh files, those are binary files that cannot be read with a Text editor. If he has access to ICEM CFD, he could open those file and then export them in an ASCII format like Fluent or Nastran…
Simon
Old   September 14, 2009, 11:45
mechovator
mechovator is on a distinguished road
Dear Save the file as part.in this will give you data in nodepad of the nodes and elements. From where you can use it in FEAp or any other program u like.
mechovator is offline   Reply With Quote
Old   September 14, 2009, 11:55
Default further explanation.
PSYMN's Avatar
Simon Pereira
Mechovator is suggesting you output it as an ANSYS mesh input file... This is similar to the suggestion of outputting it as a Nastran or Fluent MSH file, except that the ANSYS input file format is designed for FEA codes. Because of the way the FEA codes apply bocos, you will find an ANSYS input file is much larger than the same mesh output to Fluent format. It is also more difficult to read (from a CFD user point of view).
If you are developing a CFD code, then I suggest using a popular CFD output format like Fluent msh or CGNS for optimal performance. Both of these formats are also supported by ANSYS Meshing and many other comercially avialble meshing tools, giving added flexibility to your tool.
I should also add that you can use the ICEM CFD translators in batch mode to convert the UNS or domain files to the format of your choice. Do it once thru the GUI to see where the files are and what commands are needed (listed in the message window). You can also learn more about the options for each specific interface here...
http://www.ansys.com/products/icemcf...interfaces.asp
The link at the bottom of that page takes you to a table of specific formats to choose from.
Simon
Old   September 14, 2009, 11:58
How to read/write *.uns (binary) mesh file for any format:
Libraries > Output Libraries > Domain (Native Mesh) Library Description
Better ways are:
- ASCII format: Simon recommendation
- Binary format: through CGNS format (http://cgns.sourceforge.net/), neutral mesh format
Old   October 9, 2009, 15:32
Zoltán Hercz
Thanks for all help!
Finally i managed to export mesh in .msh format easily from ICEM, after some seminar in the University. I have also put my OpenGL based MESHVIEWER software(writen in JAVA) to my homepage. You can visualize .msh (tested on certain versions, and some meshes of TGrid, Gambit,ICEM) meshes with it. Please visit my site, because I would like to see that not I am the only person who visit the site.
A matrix inverter java applet can be found too here. (good for matrices with arbitrary size, but over 10x10 becomes extremly slow)
www.herczz.extra.hu
Old   October 10, 2009, 21:28
Default Viewer
PSYMN's Avatar
Simon Pereira
I checked it out and it worked on several files for me...
Your file filter only let me see or select .msh files though.
Now you need to work on being able to filter by element types, cut planes, etc.
Some more English on your site would help also... Most of the worlds engineering is done in English.
Simon
Old   October 11, 2009, 07:18
Zoltán Hercz
You are right, I just made this mesh viewer to be sure i can read the mesh for my own cfd code. I uploaded it to my page, but i forgot to change the language to english in the matrix inverter application. And actually i able filter element types, etc, because different things(diff. element types, boundaries..) in the .msh file are grouped, and i conserved this grouping.
Phase locked average in run time panara OpenFOAM 2 February 20, 2008 14:37
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
ICEM 10 mesh question DAK565656 CFX 6 May 8, 2007 12:16
Design Integration with CFD? John C. Chien Main CFD Forum 19 May 17, 2001 15:56
