Automation of mesh generation
Old   June 16, 2009, 23:07
Default Automation of mesh generation
Nishikant
nishi_bhilai is on a distinguished road
hi,
I am trying to do the following,
  1. Create model in Catia.
  2. Save as *.igs format
  3. Import it in Gambit and Mesh it and save in Fluent format
  4. Reading mesh file in Fluent 6.2.23
  5. Analyzing it then creating output file.
  6. Reading output file in notepad and check for a parameter.
  7. If the parameter is not good then changing the geometry in Catia and repeating the steps from 2 to 7.
This I am doing manually now and I want to automate this procedure. I am having only one problem:
"Step 3: Import geometry in Gambit and Mesh it and save in Fluent"
What is the command for doing this job.
I am having the journal file which would do it.
I tried /gambit ... [in <file id>] [-jou <journal file name>]
This is not working. Is this command correct?
Thanks and regards,
Nishikant
nishi_bhilai is offline   Reply With Quote
Old   September 19, 2009, 20:07
Edu
Edu-R is on a distinguished road
Hi!
I have the same problem, ¿could anyone help us?
Regards
-Edu-
Edu-R is offline   Reply With Quote
ICEM - incomplete mesh generation ralph CFX 0 June 23, 2008 23:35
need info on companies in mesh generation Ramesh Main CFD Forum 1 June 24, 2006 09:15
Mesh for 3 dim Geometry Phil FLUENT 9 July 12, 2000 04:39
General questions on grid-based computing Adrin Gharakhani Main CFD Forum 21 June 5, 2000 13:47
Mesh Mignard FLUENT 2 March 22, 2000 05:12
