convergence problem
Old   October 14, 2009, 19:02
Default convergence problem
az_f is on a distinguished road
Hi All,
My model can converge with just tet mesh but when I add the 3 layer prism mesh it can not converge. the quality of the mesh after smoothing is 0.26.Model is a bifurcation with one inlet and two similar outlets. Any suggestion will be appreciated.
Thanks
az_f is offline   Reply With Quote
Old   October 16, 2009, 15:33
Default Beauty is in the eye of the beholder...
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
The correct answer to this question would depend a lot on your solver, physics, bocos, etc. But you haven't given any info.
I recommend that you ask the question again with more info and probably ask the on the solver side of CFD-Online also.
PSYMN is offline   Reply With Quote
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 01:17
convergence problem alexandre FLUENT 2 June 14, 2007 14:31
convergence problem ammi reddy FLUENT 1 March 28, 2007 17:01
3D Fluid Flow Convergence problem Emily FLUENT 2 March 21, 2007 22:18
Non Convergence of 3D Heat transfer cfd problem Balraj Main CFD Forum 3 December 9, 2004 00:24
