How to reduce skewness in GAMBIT?
Like Tree1Likes
  • 1 Post By -mAx-
Old   October 17, 2009, 03:57
Default How to reduce skewness in GAMBIT?
lyzheng87 is on a distinguished road
Can i know how to reduce the skewness in GAMBIT?
lyzheng87 is offline   Reply With Quote
Old   October 19, 2009, 01:48
-mAx-'s Avatar
Maxime Perelli
by knowing the reason of skewed elements....
and then correct the parameters or topology
Al-Hashimi likes this.
Old   April 23, 2016, 08:36
Post
ArmanCFD is on a distinguished road
Hi. I generate tet mesh with size function to create a mesh with more density on the solid-fluid interface. My mesh has 143 elements (0.02%) that are silver and their skewness is in the range of 0.95-1.
Is this skewness leads my results into inaccurate solution or it's OK?
If so, How can I reduce the skewness?
I'll be thankful for any advice.
ArmanCFD is offline   Reply With Quote
Old   April 25, 2016, 02:16
-mAx-'s Avatar
Maxime Perelli
check where are those cells localized.
If they are in the same area, then for sure you can fix the problem with some mesh settings
Gambit help: Cube inside cube Jack Martinez FLUENT 13 August 11, 2010 06:29
gambit crashed mbgnfrx2 FLUENT 1 August 13, 2009 03:31
Severe nonorthogonality and severe skewness problem qtian OpenFOAM Running, Solving & CFD 2 January 22, 2008 18:47
Gambit -dev X11 doesn't work Ervin Amet FLUENT 0 October 28, 2007 08:33
Generating big meshes with GAMBIT on NT Andrew Ooi FLUENT 12 February 2, 2000 22:26
