[GAMBIT] size function into cylinder
Old   October 28, 2009, 10:06
Default size function into cylinder
bob12 is on a distinguished road
hi
i have meshed a cylinder and the quality is bad, so if i want a better quality i will use size function. the problem is that i know idea of which i can use, do you help me?
thanks
bob12 is offline   Reply With Quote
Old   October 29, 2009, 02:12
-mAx-'s Avatar
Maxime Perelli
post a picture a your bad quality mesh.
did you take a look at gambit tutorials?
This is the first thing to do, when we don't have any idea on a feature
Old   October 30, 2009, 01:47
Yes, i have saw the modelling guides.
now the problem is another, i have genereted a size function and the type is fixed. i can see by the command of visualize size function. the problem is that the number of mesh not change. i suppose that the command is not applied.
what do you think?
Old   October 30, 2009, 04:28
-mAx-'s Avatar
Maxime Perelli
If the number of cells doesn t change, it means that the sze function is ignored or not well defined.
If you try to modify SF, do you see the one you defined?
Old   October 31, 2009, 17:36
Default @bob12
ANIL
makaero is on a distinguished road
hi
The curved size function has to be used for curved surfaces, select the appropriate angle for good mesh.
makaero is offline   Reply With Quote
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 09:31
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
Error with Wmake skabilan OpenFOAM Installation 3 July 28, 2009 00:35
