Help with 3dwing mesh
Old   October 31, 2009, 17:29
Default Help with 3dwing mesh
ANIL
makaero is on a distinguished road
I have a wing in a box. to avoid complex mesh and to hav much grid density at LE and TE of wing, i wud like to divide the wing in many computational volumes and mesh the entire cuboid including wing.
how to do that....?
Is it necessary to hav a boundary layer over the wing for subsonic flow, inorder to calculate Cl and Cd?
Thanks a lot!
makaero is offline   Reply With Quote
Old   November 3, 2009, 01:33
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
Gambit?
if yes -->
You can divide your domain with split operations.
If your volume is stll real-volume, i twill be easy.
BL are not necessary, but for aero stuffs I would recommand to use them.
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   November 3, 2009, 14:26
ANIL
Thnx Max...
yes iam using Gambit.
I got a coarse vol. mesh, the Cl obtained from the simulation using pre-farfield BC's was only 50% of wht it has to be. i gave the corect reference values.
so i was trying to do a good mesh by further dividing it, but the unstructured grid seems to be too complex. moreover for the nxt one i hav the wavy profile for LE of wing whch might be chalenging for me to mesh.
whts the way to get an optimum mesh on wing for external flow?
i need to calculate Cl, Cd and look for Cp distribution, Pre. contours and streamlines of flow.
(Using fluent and Gambit, i jst strted using it)
Thanx once again
Old   November 4, 2009, 00:57
-mAx-'s Avatar
Maxime Perelli
you can use the face scale tool (in Face/copy) it will create a bigger wing which should surround your actual one.
Then split your domain with this surface, it will create a subvolume (kind of very big BL) which should be meshed with hex.
Then in this subvolume, you attach a real BL, and you can mesh the rest of the domain with tetra-hexcore.
It should render your work a little more easier
Old   November 9, 2009, 22:36
ANIL
hi Max
I apoligize for late reply, do u hav any tutorial files, whch helps creating sub volume around wing and mesh the remaing domain wit hex-core...
if u hav, plz send it to anilsmailaero@gmail.com
thnx a ton.
Old   November 10, 2009, 01:12
-mAx-'s Avatar
Maxime Perelli
There is no specific tutorial to your application.
Tutorial 3 (3. MODELING A THREE-PIPE INTERSECTION (3-D) ) may help you, using split tool.
This tutorial is in the help documentation, provided from Fluent-Gambit
Dynamic Mesh Problem. Tom Clark FLUENT 10 June 21, 2021 04:27
Meshing aifoil in ICEM student123a ANSYS Meshing & Geometry 13 December 8, 2010 10:40
problem when converting mesh (made by ICEM) using fluentMeshToFoam Forrest_Lei OpenFOAM 11 October 16, 2009 06:28
2d irregular grid Remy Main CFD Forum 1 December 22, 2008 04:49
General questions on grid-based computing Adrin Gharakhani Main CFD Forum 21 June 5, 2000 13:47
