[ANSYS Meshing] AnsysWB,import from DesignModeler 1Part with Surface and Solid to StructureMechanical
Old   December 30, 2014, 05:29
Default AnsysWB,import from DesignModeler 1Part with Surface and Solid to StructureMechanical
Martinw is on a distinguished road
Hi all,
Im using in Ansys Workbench the Transient-Structural system. In the DesignModeler I create a Surface-Body (surface from sketches) and a normal Solid-Body (extrude a sketch). I connected this 2 bodies to 1 single Part.
The Problem now is the geometry import to the Structure- Mechanical. It doesn't work to import a Surface-Body and a normal Solid-Body in 1 single Part. Structural- Mechanical imports only the normal Solid-Body and ignores the Surface-Body, without producing any warnings.
I need to have this to bodies in 1 single Part to create a mesh with node matching.
Does anybode know what the problem is?
Is it not possible to import a Surface-Body and a normal Solid-Body in 1 single Part?
Or have somebody another method to produce a mesh with node matching of 2 bodies?
Thanks a lot!
Martin
Martinw is offline   Reply With Quote
designmodeler, mechanical, mesh, part, surface
[DesignModeler] Question about converting surface body to solid body in DesignModeler lnk ANSYS Meshing & Geometry 2 November 24, 2013 00:02
creating solid from car body surface data Mehmet Yilmaz FLUENT 1 January 16, 2008 06:57
Can I have solid in the free surface simulation? ggbaby Siemens 0 September 5, 2006 05:45
solid edge problem....can you help? cindy Main CFD Forum 3 April 5, 2004 13:43
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
