[ANSYS Meshing] Automasing the sequential process of meshing different parts
Old   November 5, 2012, 07:44
Default Automasing the sequential process of meshing different parts
Juan Campos
juanmariacg is on a distinguished road
Hi everybody,
I am dealing with a CFX aerodynamics simulation. The geometry has two very different zones. I was trying with different methods and configurations and I get the best results of the mesh, meshing the two zones separately: I supress one part and meshing, then unsupress+supress the other part and meshing, and It works very well.
The problem is that I'm doing this process manually and I want to parametrize the model and that is going to required many time.
Is there some way to do this manual process automatically?
thank you very much in advance,
best regards
juanmariacg is offline   Reply With Quote
Old   November 5, 2012, 08:19
Josef Runsten
jrunsten will become famous soon enough
Send a message via MSN to jrunsten
Use recording.
Right click Mesh, choose Start Recording, then Start Recording again in the worksheet that pops up. Mesh the different bodies in the order you want and Stop Recording. The next time you mesh it will follow this order.
jrunsten is offline   Reply With Quote
Old   November 5, 2012, 08:33
Juan Campos
Thank you for your quick response.
I don't have this option, I've found this option is implemented in ansys 14, unfortunaly I have the 13th version yet,
Originally Posted by jrunsten View Post
Use recording.
mesh, multiparts
duration of meshing process stefank ANSYS Meshing & Geometry 10 November 17, 2015 17:12
[Netgen] meshing process stops (after surf meshing?) vaina74 OpenFOAM Meshing & Mesh Conversion 5 May 27, 2011 02:32
[ICEM] Problem vt unstructured meshing raghav ANSYS Meshing & Geometry 1 October 8, 2010 12:21
[ICEM] Basic meshing doubt vishnukmd7 ANSYS Meshing & Geometry 2 September 24, 2010 01:36
Meshing 3D AHU room khimkhim ANSYS Meshing & Geometry 3 November 4, 2009 11:26
