[ICEM] How to mesh part by part?
Old   February 23, 2010, 04:13
Default How to mesh part by part?
Rikio
rikio is on a distinguished road
Send a message via Skype™ to rikio
Hi, All,
Is it possible to mesh an entity part by part?
I want to get the tetra mesh for the complicated portion and hexa mesh for others, and connect with matched meshes. If tetra generated first, could it be freezed and generate hexa domained mesh with geometry and existing mesh?
Thanks in advance for any information.
rikio is offline   Reply With Quote
Old   February 23, 2010, 07:05
Amol Ramteke
Goldsstean is on a distinguished road
I suggest to create Hexa first and then go for Tet.
Or first simply create the Quad mesh on the interference face, the create tet mesh which will create prism and interface, and then go for Hexa.
Goldsstean is offline   Reply With Quote
Old   February 23, 2010, 09:00
Rikio
Thank you, Amol.
I tried to generate Hexa first, but they will be deleted when creating Tetra mesh without any prompt. Is there any options to be checked?
Old   February 23, 2010, 09:59
Amol Ramteke
plz upload journal file let me see the issue.
Old   February 23, 2010, 20:39
Rikio
Thank you, Amol.
Take a rectangular tube as an example, part of it is meshed with hexa, and tetra for the rest.
I create block to generate the hexa first, and then define mesh parameters to tetra mesh. When computing volume mesh, previously generated hexa mesh was deleted. Only the specified "existing mesh" was kept, and divided into tetra.
The resultant mesh is shown in the attached JPG. And the journal file is also listed out. :-)
Old   February 24, 2010, 09:54
Default Merge Tetra and hexa.
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
There are tutorials for this... Look for the HVAC tutorial.
What you need to do is mesh the two meshes separately and then merge tetra and Hexa at an interface. I have other posts about this that you can take a look at.
PSYMN is offline   Reply With Quote
Old   February 24, 2010, 19:19
Rikio
Yes, I have read through it. Maybe this is the only solution.
Thanks to all of you.
[ICEM] Is it possible to blocking and mesh part of geometry? zhaohui ANSYS Meshing & Geometry 5 March 25, 2016 05:12
basic of mesh refinement arya CFX 4 June 19, 2007 12:21
ICEM 10 mesh question DAK565656 CFX 6 May 8, 2007 12:16
Mesh distortion close to cylind wall-GAMBIT 2.2.30 Mirek FLUENT 1 April 15, 2006 17:22
General questions on grid-based computing Adrin Gharakhani Main CFD Forum 21 June 5, 2000 13:47
