[ICEM] Problem with a volume mesh generation
Old   March 5, 2013, 01:42
Default Problem with a volume mesh generation
Evgeny Cherniakov
jekmann is on a distinguished road
Dear All,
I am trying to make a model of the cleanroom with moving person (with ICEM-CFD). But there is a problem with volume meshing.
The geometry is simple (files are below) but I don't know, why is a problem with volume meshing? (surfaces are meshed well)
Does anybody have an experience with ICEM-CFD meshing? Could you tell me, where could be a problem with volume? Because I have no a big experience with ICEM-CFD (Before ICEM-CFD I have used another software)
Thanks.
meshing files: http://depositfiles.com/files/has0aedqj
Last edited by jekmann; March 5, 2013 at 01:50. Reason: add link for meshing files
jekmann is offline   Reply With Quote
Old   March 5, 2013, 04:41
Evgeny Cherniakov
I have found strange thing in meshing:
If I meshed all geometry "Hexa" - all surfaces are meshed, but volumes aren't;
The error is following: error orienting normals, perhaps there is more than one region error in output_region_boundaries.
but if I meshed all geometry "Tetra" - the volumes are meshed, but the surfaces, which are "connected", I mean surfaces which are "interface" between LEFT-INTERIOR and MOVING-MESH-FRONT-LEFT and etc. (inside the geometry model) aren't meshed. You can see it at the attached link above.
Old   March 6, 2013, 21:24
Smile
huzi
wenshenghu is on a distinguished road
How to download the mesh file?Maybe I could help you
wenshenghu is offline   Reply With Quote
Old   March 6, 2013, 21:28
huzi
Hi, email is huwenshengxiaohaha@163.com. You can send the mesh to me.
Old   March 7, 2013, 12:46
kad
kad will become famous soon enoughkad will become famous soon enough
For tetra meshing you have to define the interface surfaces as internal walls under part mesh setup.
Also blocking for this geometry should be pretty easy, even for a beginner. Just look for some tutorials and go for it.
The internal wall option only applies to Octree. To mesh the interface surfaces you have to associate the faces to their corresponding surfaces.
kad is offline   Reply With Quote
icem-cfd, volume meshing
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface Kryo OpenFOAM Meshing & Mesh Conversion 13 February 17, 2022 07:34
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
mesh generation problem Ellen FLUENT 7 February 18, 2009 21:20
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
Latest news in mesh generation Robert Schneiders Main CFD Forum 0 March 2, 1999 04:07
