Aspect Ratio of Quad in ICEM
Old   May 1, 2010, 04:38
Lightbulb Aspect Ratio of Quad in ICEM
Amod Kumar
amod_kumar is on a distinguished road
The "Aspect Ratio" of a quad element in ICEM CFD is defined as the ratio of distanced between opposite vertices (shorter diagonal / longer diagonal). This definition imply that all regular rectangles (right-angled quadrilaterals with equal opposite sides) will have A.R. = 1 which is not correct.
Am I interpreting it wrongly?
Thank you for your attention!
Amod
amod_kumar is offline   Reply With Quote
Old   June 7, 2010, 15:45
Red face Bad doc
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Yes, this is not correctly shown in the help A quick test reveals that it is calculating aspect ratio correctly and not how it is described in the help.
Thanks for catching and reporting this.
I think the actual calculation may be the ratio between oposite midsides instead of diagonal corners...
I have reported this to the doc team and they should fix it for the next release.
I will try to post the correct doc here if I remember.
PSYMN is offline   Reply With Quote
Old   June 8, 2010, 19:39
Default Aspect Ratio of a Quad...
PSYMN's Avatar
Simon Pereira
We got the correct definition from Development and added it to the help. I created this image to help illustrate (we will put it into the help also).
Best regards (and thanks for catching this doc error),
Simon
aspect ratio vs. y+ hammam CFX 3 August 6, 2007 10:41
High Aspect Ratio elements Flavio CFX 2 November 24, 2006 12:01
does aspect ratio affect analysis mahesh Main CFD Forum 2 October 10, 2005 09:12
Aspect Ratio at high turbulent and swirled flows zago FLUENT 0 May 19, 2004 02:37
aspect ratio ditto CFX 7 May 11, 2003 11:19
