Gambit Merging edges
Old   June 9, 2010, 11:08
Default Gambit Merging edges
Krishan Parmar
Krish is on a distinguished road
Hi I am having a problem with Gambit for my optimization code. I am trying to add an ice shape to my airfoil in a way that I can run a journal file via my optimization code.
The reason the solution need to be simple but effective is because the ice shape position will vary with each iteration. Therefore a suitable way to 'stick' the ice shape to the airfoil is needed.
The problem I have is that the curvature of the airfoil does not allow me to join the ice shape to the airfoil without actually calculating the correct distance and curvature to provide the correct rotation to the ice shape.
This method cannot be performed in an automated fashion regardless of how many variables I add to the journal file.
I need a method (or a tool that I do not know about) to help join the ice shape to the airfoil surface as neatly as possible. A poor join will not provide the accuracy of results I need. I am using real ice shapes but cannot add them here, instead I have attached a simple shape for reference purposes:
Any help would be much appreciated.
Thanks in advance
Krish
Krish is offline   Reply With Quote
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
Edges in Gambit Naghman Khan FLUENT 3 October 3, 2007 06:36
gambit: mesh edges, change direction Ralf Schmidt FLUENT 2 August 29, 2006 10:55
Deleting Edges in Gambit Alberto Schroth FLUENT 4 May 31, 2000 14:15
