June 20, 2010, 10:02 |
outlet shap changed
hi every one
i'm using icem. i'm modeling a tank with a circular outlet. i generated hexa mesh and i splited blocks at the outlet (outlet is placed at middel of the one side of the tank). when i open the icem file in CFX and select the outlet it seems to be a rectangular. is there any problem with mesh or geometery? best regards |
June 21, 2010, 09:48 |
Associations
Simon Pereira
Rep Power: 47 |
If you mean that your outlet patch of mesh (as viewed in CFX) is rectangular...
My guess is that you didn't associate the edges (blocking) of the outlet to the curves (geometry). Therefore the outlet edges default projected to the surfaces instead making a rectangle instead of a circle. To improve this, go back to ICEM CFD and associate the correct edges to the circle... You may also need to create an OGrid in this area to avoid the problems associated with mapping HGrid quads to a circle. At the bare minimum, go into the OGrid tool and select the outlet face as a face. This will automatically select the adjacent block. Hit apply. Depending on your particular geometry, much better OGrid implementations may be possible, but I would need an image or tetin file to provide a better suggestion. |
June 22, 2010, 01:00 |
hi simon
tanx a lot for your comprehensive description. i'll send a tetin file. |
Disturbed flow field at outlet boundary (Multiphase flow through pipe) | Michiel | CFX | 17 | April 21, 2010 10:14 |
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 15:45 |
CCM+ Outlet BC for Ship Resistance | Steve | Siemens | 3 | May 8, 2008 19:12 |
VOF Outlet boundary condition in cfd - ace | JM | Main CFD Forum | 0 | December 15, 2006 08:07 |
Impinging Jet. Outlet Boundary Condition | Vincent | Main CFD Forum | 0 | December 16, 2003 10:49 |
