[ICEM] Meshing Issues in ICEM
Old   May 24, 2010, 13:21
Question Meshing Issues in ICEM
Amod Kumar
amod_kumar is on a distinguished road
Hello All,
Though I highly appreciate ICEM CFD, lately extensive usage of this software has revealed lot of weakness in this software. I hope my message reach to the development team:
1. Periodicity and Swept block: Even when periodicity is set on vertices, if an array of blocks encompassing the tow faces of periodic surfaces are marked as Swept, the priodicity gets lost. This is very troubling as you have no other option but the swept blocks to reduce the node count on parallel edges.
2. The "Pre-mesh Quality" under Blocking menu calculates Equi-angle Skewness of prism element zero. However, mesh quality under edit mesh seems to be OK. This is very time consuming.
3. The definition of ASPECT RATIO under Pre-mesh Quality and Edit Mesh Quality is on different scale. Why can't both the method reports A.R. on same scale (say either 0~1 or 1~ infinity).
4. The swept block method works well (i.e. generates good quality mesh) only when the associated faces are plane. On curved faces, they tend to make highly skewed hexa/prisms.
5. When blocking is active and user tries to set mesh count on a particular line or surface, the Edge Parameter setting on edges gets changed to some arbitrary number even when Update Parameters button has not been used. This is required in V12 where a surface mesh can be associated to free face of the swept block.
6. Many times when you use UNDO button, the colour scheme of parts under model tree gets changes to same colour.
7. Even when the geometry is a cuboid, it is impossible to generate All-Hex mesh without using Blocking technique.
With growing timeline pressure, I think it is wiser to recommend my manager to switch to other software such as ANSA or AutoGRID. I see no major development in ICEM since last 3~4 years.
amod_kumar is offline   Reply With Quote
Old   June 21, 2010, 11:26
Default Duplicate...
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
http://www.cfd-online.com/Forums/ans...sues-icem.html
PSYMN is offline   Reply With Quote
[ICEM] Meshing Issues in ICEM amod_kumar ANSYS Meshing & Geometry 4 June 23, 2010 07:57
[ICEM] Need help in ICEM CFD Mapped Meshing falconf16 ANSYS Meshing & Geometry 3 February 19, 2010 14:21
ICEM Meshing Jaloha CFX 0 April 1, 2008 06:24
Missing tets along line when meshing with ICEM CFD Georges P. Côté CFX 6 March 23, 2006 00:34
ICEM meshing problem Forrest CFX 4 May 25, 2005 18:37
