Change parameters for Hybrid mesh
Old   July 16, 2010, 01:09
Default Change parameters for Hybrid mesh
Karan Anand
karananand is on a distinguished road
I have a hybrid mesh (Tetra with hex core). I can adjust the max element size for tetra and hex. however, is there a way that I can define the number of layers or max height (thickness) of the tetra elements with the hexcore option enabled?
What I have seen is that the hex-core automatically determines the height of the tetra and hex layers. I tried changing the tetra ratio, height etc from the surface mesh, but nothing seems to work!
Also another question. Is there a way that I can increase the mesh density of the tet in one area (closer to one wall and reducing outwards until it hits the other wall) without the mesh density option in ICEM. I want a gradual decrement in mesh density for the unstruct tet mesh. (again using the height ratio didnt help!!
karananand is offline   Reply With Quote
Old   July 16, 2010, 01:15
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
which software?
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   July 16, 2010, 12:12
Karan Anand
Sorry: ICEM
I have added couple of pics to show the coarse mesh:
http://img689.imageshack.us/gal.php?...ucthexwith.jpg
Old   July 18, 2010, 16:37
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Nope, sorry, the Hex Core doesn't provide that option to set the offset to the user...
Instead of Hex Core, I usually use the 12 tet to 1 hex conversion. This basically turns the octree tetras back into the original hexas...
As for wanting a smoother transition in tetra mesh size from one wall to the other, your best bet is to use the Delaunay method (perhaps with TGlib AF). The size transitions are built into OCTREE's algorithm, but you could start with Octree, then delete the volume mesh and smooth the surface mesh with laplace, then generate the delaunay fill and you will get your nice smooth transition.
PSYMN is offline   Reply With Quote
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 06:42
[ICEM] How can I set the edge parameters so that they override the part mesh setup? Josh ANSYS Meshing & Geometry 1 April 16, 2010 13:33
basic of mesh refinement arya CFX 4 June 19, 2007 12:21
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
