Load unstructured hex-mesh as blocking in icemcfd
Old   July 14, 2010, 06:23
Default Load unstructured hex-mesh as blocking in icemcfd
Michael Kornhaas
korni is on a distinguished road
Hi all,
does anybody know if it is possible to load an unstructured hex mesh as blocking in icemcfd? I found the option under the load blocking menue. But I get a segmentation fault...
Regards Michael
korni is offline   Reply With Quote
Old   July 15, 2010, 20:45
Default Should Work
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Yup, it is possible. Not sure why you got a segmentation fault. Perhaps the resulting blocking was too complex or had unstructured regions or something and you ran out of memory while it was figuring everything out. It usually works for me and I have done some pretty interesting models.
Where did the model come from? Even though it was an unstructured mesh, did it come from a structured multi-block mesher (such as GridGen or TrueGrid)? Those usually work for me. I once had a spinal segment fail the first time (it was very complex), but there was a message (not a segmentation faliure) and it worked in the end. I don't recall what I had done wrong.
Purely Unstructured meshers may give you a mesh that can't be converted...
If you have access to TECH support, you could send it their way.
techsupp@ansys.com
Simon
PSYMN is offline   Reply With Quote
Old   July 16, 2010, 04:28
Default works on 32 bit machine
Michael Kornhaas
Dear Simon,
thank you for your answer. It retried it on a 32 bit machine and it worked. The segfault appears only on 64 bit machines (2.6.26-2-amd64 Kernel with debian-Linux).
I want to use the pure hex mesher from Ansys12 to generate an unstructured hex mesh for a very complex case and use that mesh as blocking. Do you think there is a chance that this works?
Regards Michael
Old   July 16, 2010, 16:15
Default Will Submit a defect...
PSYMN's Avatar
Simon Pereira
I will submit a bug about this and see what testing says...
As for your particular mesh, if it can properly be broken up into mapped hexa blocks, you should be fine... If some blocks contain swept triangles or swept strange hexa patterns you may have difficulty.
Simon
Old   July 21, 2010, 17:40
Default Unsupported platform
PSYMN's Avatar
Simon Pereira
Hello Michael,
I checked with testing and they don't officially support debian-Linux (or test on it). Actually, this is the first I have even heard of it. However, they assure me that this functionality is well tested (manually and in our scripted regression test suite) and works on our supported platforms such as SuSE 10 64 bit and RedHat 4/5 Linux 64bit systems.
For a full list of supported platforms, please see the install guide. ICEM CFD may run on other configurations (I guess it *mostly* works on debian Linux ), but we have seen issues like this pop up.
Best regards,
Simon
Moving unstructured mesh with changing topology meaton OpenFOAM Running, Solving & CFD 6 April 27, 2008 07:56
Mesh motion Hex cells vs tets kev4573 OpenFOAM Running, Solving & CFD 6 December 13, 2007 14:37
Hex Core Mesh Bob FLUENT 0 May 28, 2004 13:16
Mesh Mignard FLUENT 2 March 22, 2000 05:12
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 10:09
