[ICEM] Pre-mesh: missing surfaces
Old   July 22, 2010, 04:23
Default Pre-mesh: missing surfaces
AB
BrolY will become famous soon enough
I attached two pictures which show my issue.
When the pre-mesh is created, there are missing shells. My blocking seems good, so I don't understand where it comes from.
Any help is welcome
Thanks,
BrolY is offline   Reply With Quote
Old   July 23, 2010, 09:33
Default Face to part
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
There is probably another surface very near by, but in a different part... the premesh is reaching the one surface just before the other (it may be 0.000001 closer in some spots). There are shells there, but they are in the different part. Since you have turned that part off, they do not appear.
If it is just a duplicate part, you can probably remove it. If it is the boundary of an adjacent volume and you just want this mesh to be in a specific part without removing the other part, You can force association of those faces to the specific part...
Blocking tab => Associate => Associate Face => to part.
PSYMN is offline   Reply With Quote
Problems modeling CONTACT SURFACES with CFX Mesh MAldaz CFX 2 September 12, 2006 17:10
Points on surfaces in a rotating mesh Martin FLUENT 0 August 22, 2000 13:36
Mesh for 3 dim Geometry Phil FLUENT 9 July 12, 2000 04:39
Mesh Mignard FLUENT 2 March 22, 2000 05:12
