How to change the nature of boundary conditions ?
Old   July 27, 2010, 11:08
Default How to change the nature of boundary conditions ?
Quentin
Bedotto is on a distinguished road
Hello everyone,
I'm a beginner with Icem and I have a little problem here. I've created a mesh with Icem and I've exported it in .msh for fluent. In this mesh I created curves in order to build the structure of my mesh (2D, path dependance), physically these curves are virtual and I would like to define them with the boundary condition: Interior. But I can't! I've the choice between Velocity inlet, pressure outlet, etc.... How can I modify the boundary value of these curves?
I think the fact that these curves are the frontier between differents meshes is the core of the problem...Maybe the key is to merge all meshes in order to have only one mesh finally? But how can we merge 2d meshes in ICEM?
My best regards
Quentin.
Bedotto is offline   Reply With Quote
Old   August 2, 2010, 16:08
Default How did you generate it?
PSYMN's Avatar
Simon Pereira
Right, it is a "single" sided edge, meaning that it only has shell elements on one side of it. This limits its possible bocos and does not include "internal" (which would only be valid for double sided edges (with shells on both sides).
In order too suggest the easiest way to stitch this up, I need to know what kind of mesh it is and how you generated it...? Was there much mesh editing or did you just generate it that way...?
A pic would help.
Simon
Old   August 5, 2010, 12:19
Quentin
Thanks for the reply PSYMN. I have found the solution by activating "Respect line elements" in mesh parameters. Thus the mesh sees the edge as an internale element of the mesh!
Old   August 6, 2010, 00:12
PSYMN's Avatar
Simon Pereira
Great, glad you figured it out...
Impinging Jet Boundary Conditions Anindya Main CFD Forum 25 February 27, 2016 12:58
non reflective boundary conditions for incompresible flow Pascal_doran OpenFOAM Programming & Development 16 August 25, 2015 05:35
CFX doesn't continue calculation... mactech001 CFX 6 November 15, 2009 21:25
No results for solid domain Gary Holland CFX 10 March 13, 2009 03:30
Concentric tube heat exchanger (Air-Water) Young CFX 5 October 6, 2008 23:17
