[GAMBIT] auto close Gambit window
Old   August 25, 2010, 11:31
Default auto close Gambit window
MEHDI
MEDI is on a distinguished road
Hello, everyone.
I want to use the gambit as a batch process (using the journal file), and after the gambit run, the control does not come back to command prompt due to this Gambit startup window (small window which you get when you first launches the gambit by GUI). As a result, I cannot process the next batch job automatically. (I always need to click the "close" button manually on this window) Does anyone know how to setup the gambit so that this startup window does not appear?
MEDI is offline   Reply With Quote
Old   September 3, 2010, 06:18
Jenik is on a distinguished road
HI
I have similar problem. I was creating optimization loop in VBA (visual Basic for application). The only way I discovered is to send keys alt+f4 that closes this window. The problem is that you have do it in right time. Usualy I exported mesh and after picture. The picture was sign that the mesh was succesfully exported.
Problem is that sendkeys method works in winXP, but in win7 or Vista it might not work.
Jenik is offline   Reply With Quote
Gambit Startup Window Jay Shim FLUENT 2 February 12, 2015 14:05
Gambit 2.3.16, Xming or Exceed...HELP! bambam3417 FLUENT 10 May 7, 2010 12:39
can window VIsta support Gambit and Fluent? fadhil FLUENT 5 June 19, 2008 16:52
Canvas window does not close oduor CFX 5 June 12, 2002 21:53
