[ICEM] problem vt the unstructered meshing
Old   September 30, 2010, 03:34
Default problem vt the unstructered meshing
Raghav
raghav is on a distinguished road
hi
as i create unstructured mesh for my geometry several "created material points" are generated. Also when i import the mesh to CFX it carries volume mesh of the above created material points. How to overcome this?
raghav is offline   Reply With Quote
Old   September 30, 2010, 03:40
AB
BrolY will become famous soon enough
This is normal. For an unstructured mesh, you have to create a material point (also called "body") where your mesh will be located.
So, this is not an issue !!!
BrolY is offline   Reply With Quote
Old   October 1, 2010, 05:53
Raghav
thanks. have u used bladegen tool?
Old   October 3, 2010, 14:35
Default Create your own.
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
If you don't want the tool to create its own material points, you should create at least one in the fluid region.
This is how the Octree method marks which elements are within each region. If you create at least one material point, it will assume that all the other regions are not within the flow domain and will not give you mesh for those regions.
PSYMN is offline   Reply With Quote
Old   October 4, 2010, 04:13
Raghav
thanks. when i create the material points will it reduce the number of 2d regions in cfx after importing the mesh to cfx?
Old   October 5, 2010, 18:27
Default Nope.
PSYMN's Avatar
Simon Pereira
Is this a 3D model? I assume so, in which case, I assume the 2D regions are boundary regions? These are determined by the part names for your surfaces...
If you have just an inlet, outlet and walls for your surface geometry, you will have just three boundary regions in CFX (or FLuent or whatever). If you have a bunch of parts or perhaps a different part for each surface, then the mesh will form with shells in each part and you will have lots of bocos to deal with...
The material points is the equivalent, but in the volumes. These are separate issues.
Simon
[Other] Hex meshing problem DM12 patrick ANSYS Meshing & Geometry 7 January 9, 2015 07:21
Gambit meshing problem nana ANSYS Meshing & Geometry 5 August 31, 2009 05:58
Meshing problem in GAMBIT Vidya Raja FLUENT 0 May 20, 2006 23:31
Problem meshing very thin pipe B. Hemmen FLUENT 2 May 16, 2006 08:29
Meshing problem... Gustaf CFX 2 March 28, 2003 10:37
