Making wing geometry in Ansys 12.1
Old   November 1, 2010, 13:45
Default Making wing geometry in Ansys 12.1
Akash
akash_morar is on a distinguished road
Started working on designing an F1 front wing on Solidworks last year but now have to do it using Ansys 12.1's design modeler. I cant import the solidworks geometry in due to install errors.
Basically how can i make a 3D wing. Is there a way to extrude a curve or import in a curve file and then convert it into a sketch like i can do in Solidworks?
Any help would be good as well as if there are better ways to making a wing using the modeler.
Thanks
akash_morar is offline   Reply With Quote
Old   November 1, 2010, 16:35
sac
sac is on a distinguished road
Then why not reinstall it - it would probably be the easiest way since you have already made the geometry. What error message as you getting? Do you have solidworks installed on the machine?
There are lots of ways you can do this.
Importing a points file can be done under the point feature.
Or you could create points using jscript from a file. An easy way of doing the latter is to create a few points and then in the file menu ask it to "write out script of active plane" (or something similar can't exactly remember the wording).
sac is offline   Reply With Quote
Old   March 7, 2011, 11:24
Rohit Vasudevan
rohit_8481 is on a distinguished road
@Akash
I'm doing a similar project... I seem to be having the same problem where i can't seem to extrude a 3D curve...
But i did import the curve into ansys... vut cant seem to do anythin with it... U basically import the data points into ansys in a specific format.. X, Y and Z triples basically...
rohit_8481 is offline   Reply With Quote
Old   September 26, 2013, 14:46
Pjotr
oewnce932c is on a distinguished road
hi all, i know the topic is not that new
but i wrote a tutorial -ANSYS DesignModeler: import XYZ points from file, make splines, surfaces and body. + Meshing
cheers
yachting_rus cup
world amateur racing tour
WWW.YRC.DK
oewnce932c is offline   Reply With Quote
ansys 12.1, design modeller
Evaporation model in ansys Fluent 12.1 oldisbest Fluent UDF and Scheme Programming 12 March 26, 2020 09:11
Ask for Wing LANN 's Geometry file ccyx Main CFD Forum 2 March 11, 2013 09:01
ANSYS 12.1 tutorial katiyon CFX 8 December 2, 2011 04:09
Delta Wing Geometry Apurva Shukla Main CFD Forum 2 May 26, 2001 07:26
Where to find 3-D Wing Geometry? G.P. Xia Main CFD Forum 4 May 28, 1999 10:44
