[ICEM] Mesh along axis for a wedge gives elements with extreme aspect ratio
Old   November 17, 2010, 06:57
Default wedge mesh with Y-block gives large aspect ratio perpendicular to axis
Sangram
sangrampp is on a distinguished road
Hello guys,
i am having a problem with meshing a wedge component. basically the component is two concentric cylinders - one very small (100 orders of magnitude smaller than the other) and other bigger surrounding it (setup as 30 degree periodic). i have setup two blocks each for the two cylinders - both the blocks are concentric since the cylinders are so. the problem starts when i mesh them the elements in the bigger cylinder are larger than those in smaller block and hence when i mesh the axial edges the elements in the smaller block get very large aspect ratios and if i mesh to take care of the smaller elements the large elements get large aspect ratios (around 0.003 and less). i am targeting aspect ratio >0.3.
can anyone please tell me how to go about doing this such that the axial element aspect ratio is same for smaller elements and larger elements.
sangrampp is offline   Reply With Quote
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
2d irregular grid Remy Main CFD Forum 1 December 22, 2008 04:49
DOES ASPECT RATIO PLAY A PART IN CFD RESULTS? RIF Main CFD Forum 2 January 5, 2008 13:14
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
