[DesignModeler] Create face from edges
Old   February 2, 2011, 10:23
Default Create face from edges
fatma
code_source is on a distinguished road
I have two edges that do not touch and I want to create a face from these edges.
On Gambit, I used the skin function and it works well:
face create skin "edge.20" "edge.28" directions 0 0
The difficultie with DesignModeler is that makes "skin" using sketches not edges.
if anyone has an idea, it will help me a lot.
Thank you
code_source is offline   Reply With Quote
Old   February 5, 2011, 13:35
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
The skin/loft command will work from named selections as well as sketches. You could select the edges of your faces (with the edge selection mode), right click and create named selections... Then try the skin command referencing those named selections instead of sketches.
There is also an option from one of the pull downs to create a surface from edges, but I am not sure if it works with an open set like that.
Sorry I have not actually tried these lately (I don't have the software up in front of me) but I know they are there and they are worth a shot.
PSYMN is offline   Reply With Quote
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 05:50
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
