[ICEM] Export unstructured periodic mesh from ICEM CFD to Fluent
Old   January 28, 2010, 08:17
Default Export unstructured periodic mesh from ICEM CFD to Fluent
ivan
ivanddd is on a distinguished road
I want to solve aircraft propeller with MRF in Fluent 12.1 . I solved this in cylindrical computation domain and there is very good agreement with analytical solution.
When I tried to create periodic mesh (180° cylindrical domain) in ICEM CFD there were this situation :
1)coarse unstructured grid works without problems in ICEM CFD and Fluent
2) When I tried to use unstructured grid with prismatic layers (about 15 prism layers), the problem was not in ICEM CFD but Fluent's check reported :
WARNING: left-handed faces detected on zone 20: 420388 right-handed, 61 left-handed.
I used grid>modify zones>repair-face-handedness but probles is still here.
3) I used unstructured grid with one prismatic layer the problem was not in ICEM CFD and Fluent's check.
Does somebody know, what should I do.
Thanks very a lot.
(Sorry for my English)
ivanddd is offline   Reply With Quote
Old   February 3, 2011, 00:51
Shankar
shankar1221989 is on a distinguished road
Dear Ivan,
The problem with left handed faces comes when the surfaces forming the tets/prisms are not of good quality. This typically happens when the surface mesh in tricky regions are not fine enough, or the growth rate in these trichy regions are high.
when I say tricky regions, it means regions with highly acute sections.
check out for such sections..if you hav any..separate out such sections, generate a finer mesh and give a lower growth rate in the prism layer....
hope this helps..
shankar1221989 is offline   Reply With Quote
unstructured mesh phoenics user Phoenics 26 March 22, 2012 12:17
How to export 2-D mesh from ICEM CFD for CFX karimakhtar ANSYS Meshing & Geometry 13 November 3, 2011 09:36
Problem in IMPORT of ICEM input file in FLUENT csvirume FLUENT 2 September 9, 2009 01:08
Boddy fitted Hexcore Mesh in ICEM Cfd Mitch CFX 0 December 29, 2008 06:07
How to corse mesh in icem cfd? Priety CFX 2 October 2, 2006 03:57
