complex geometry/structured hexahedral mesh
Old   February 4, 2011, 09:59
Default complex geometry/structured hexahedral mesh
Lilly is on a distinguished road
I want to mesh a tricky geometry: it’s a vessel (reconstructed from MRI/CT data) having a „non-round“ cross section, an uneven surface, variations in diameter and several bifurcations. Do you have any idea how I could generate a structured hexahedral mesh for this kind of geometry using Gambit or TGrid? I failed several times doing it…
If it’s not possible, do you have any hint for a good open source software I could use?
Thanks a million for your help!
Lilly
Lilly is offline   Reply With Quote
Old   February 5, 2011, 14:16
Default ICEM CFD Hexa FTW
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
ICEM CFD Hexa is the best tool for this. It has advantages such as very flexibly geometry import, patch independence, a flexible blocking topology layer that elastically projects to the geometry and can be easily tweaked or fit to other similar geometries, easily inserted OGrids (boundary layers), support for really large models (if you need that), the ability to create sub topologies and then assemble them later, interactive mesh/blocking diagnostic and editing tools, scripting, output to a wide variety of solver formats, etc.
By far the best tool available for biomedical applications requiring structured hexa.
PSYMN is offline   Reply With Quote
Generate hexahedral mesh pluto STAR-CCM+ 4 November 7, 2017 02:43
Gambit problems Althea FLUENT 22 January 4, 2017 03:19
engrid -> save as .stl with boundarie codes Zymon enGrid 31 August 29, 2011 13:40
[Other] Hexahedral mesh generation makotohonda OpenFOAM Meshing & Mesh Conversion 0 July 12, 2010 22:24
Hexahedral mesh with CFX-Mesh isabel CFX 3 March 6, 2007 05:24
