[Other] exchange of parameter values between TurboGrid and DesignModeler in Workbench
Old   January 17, 2011, 10:18
Default exchange of parameter values between TurboGrid and DesignModeler in Workbench
la7low is on a distinguished road
I declared parameters in TurboGrid and DesignModeler too. They appear in the parameters workspace in Ansys Workbench, so everything is fine. Now, how can I assign a DesignModeler parameter value with a TurboGrid parameter value? If I write its name in the so expression field it does not recognize it...see attached picture
The question could be more general how to exchange values of parameters between any Ansys components (can be DesignModeler, Fluent, CFX, Mechanical, TurboGrid etc.)?
Thanks for any help in advance!
la7low is offline   Reply With Quote
Old   February 18, 2011, 08:57
Default Use the Parameter ID, not name.
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Maybe it could be more flexible... I will see what we can do.
In the mean time, you don't type in your name for the parameter (TT2), you type in the Parameter ID, (P11).
So, in your expression for P10 (aka BB), you should type in "P11".
The result will be that P11 will always have the same value as P10, and that P11 will be the source (as P11 changes, P10 will match it)
Best regards,
Simon
PSYMN is offline   Reply With Quote
Old   February 21, 2011, 15:12
yes with the Pxx name I can assign another parameter, but the frustrating things are the dimensions. DM parameters are dimensionless by default and can not be changed even with a script (tried that), while TurboGrid parameters will aways have a unit (dimension). So it is not that easy, but I solved that too by non-dimensionalising Turbogrid parameters.
So I wish parameters could be more flexible to assign and Pxx names are hard to follow as that can not be changed and Pxx is not an informative name. Also it would be nice if parameters coming from any program would all either be dimensionless or with dimension. These could have saved me some time and hassle...but anyway could find a way to circumvent these...
But thanks for the post and best regards,
lazlow
parameter set, parameters workspace
