Ansys 12 Error
Old   February 21, 2011, 01:06
Default Ansys 12 Error
Secu is on a distinguished road
Recently I have installed the new version of Ansys, 13. When I want to run Ansys Workbench I get the Send/Don't Send error. The same happens when I want to uninstall it. How can I fix this?
N.B.: I am using a Toshiba Laptop with Windows 7 x64 which could ran just fine Ansys 12.
Thank you.
LE: I have resolved the problem. After the clean install of Windows 7, I installed de display drivers and so appeared the incompatiblity which caused Ansys to crash. After unistalling the display drivers manually installed, Ansys just works fine.
Secu is offline   Reply With Quote
Compile calcMassFlowC aurore OpenFOAM Programming & Development 13 March 23, 2018 07:43
UDF: DEFINE_CG_MOTION for vertical jump motion of an electrode! alban Fluent UDF and Scheme Programming 2 June 8, 2010 18:54
POSDAT problem piotka STAR-CD 4 June 12, 2009 08:43
[Netgen] Installation of Netgen in SuSE Linux 92 edvardsenpriv OpenFOAM Meshing & Mesh Conversion 23 January 16, 2009 06:12
How to get the max value of the whole field waynezw0618 OpenFOAM Running, Solving & CFD 4 June 17, 2008 05:07
