[ANSYS Meshing] how to accelerate graphic process in icem-cfd
Old   March 4, 2011, 23:08
Default how to accelerate graphic process in icem-cfd
adam2008 is on a distinguished road
hi,
I generated a huge number of elements in ICEM-CFD 12. Now it takes relatively long time to refresh the graph if I change views (rotate etc). Can I do something to make it quicker?
thanks a lot
adam2008 is offline   Reply With Quote
Old   March 5, 2011, 10:40
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Update to 13.0... Some types of elements had their display sped up by 10 to 25 times...
PSYMN is offline   Reply With Quote
Old   March 5, 2011, 10:42
PSYMN's Avatar
Simon Pereira
Also, why are you displaying all the elements...? Some new users have a bad habit of trying to display all the volume elements (maybe that is what you are doing). You should only display the volume elements when the cut plane is on. Other wise you can only see the outer surface anyway and should just be displaying the shells.
Old   March 5, 2011, 15:30
thanks a lot. I actually only want to display the shell. The problem is, even with only displaying shell, the graphic refreshing is still slow due to large number of mesh. The tet mesh number is about 4 million nodes/20 million elements. I have a 1GB nvidia 3D card and computer is a 8CPU/24GB RAM workstation.But glad to know 13 version may have better performance. Meanwhile, can i do something in "setting" by adjusting numbers in speed/memory?
Thanks a lot for any advice.
Old   March 6, 2011, 17:11
Default Use OpenGL Feedback
PSYMN's Avatar
Simon Pereira
There are lots of settings for improving geometry performance (Such as "Auto Simplify"), but not mesh...
However, that would not be considered a large model. You should be able to spin that pretty easily... I can and I have a more than 3 year old Dell M4300 with only a single CPU and much less memory running 32 bit Win XP. I often go up to 10 or 12 million cells.
Have you turned on the Display setting for "Use OpenGL Feedback"?
Old   April 14, 2011, 18:51
john pham
l0ngj0hnz is on a distinguished road
Hi Simon,
Would tweeking the numbers in Settings -> Memory have any effect on display performance. I am working with a 40 million cell mesh. How much RAM do you think will be sufficient to display this mesh efficiently. Thanks in advance.
l0ngj0hnz is offline   Reply With Quote
ICEM CFD License boris Main CFD Forum 3 March 15, 2004 00:16
ICEM CFD Modules Boris FLUENT 1 March 12, 2004 14:37
Errors in CFD Lily Kabanj FLUENT 8 May 1, 2000 07:52
ASME CFD Symposium - Call for Papers Chris R. Kleijn Main CFD Forum 0 September 8, 1998 08:19
ASME CFD Symposium - Call for Papers Chris R. Kleijn Main CFD Forum 0 September 3, 1998 08:45
