May 19, 2011, 16:14 |
Merge 2 unstructured meshes
Rep Power: 14 |
I use ICEM CFD v12.1. My geometry is very simple. As you see on the attached figure, I have two cubes sharing a common interface. The mesh inside the buttom cube was created with octree method. The mesh inside the top cube was created with blocking method, but I created only penta elements inside this blocking. At the commun interface between the two cubes, the mesh is perfectly connected node to node. I converted the mesh inside the top block in unstructured mesh. So I have two unstructured meshes sharing a commun interface and at the interface the two meshes are connected node to node. After that, I check the mesh with check mesh tool in ICEM and it says: «656 problems were found for Penetrating elements». How do I successfully merge the two meshes??? Best Regards, Vinc |
[ICEM] merge two hexa meshes | gajemon | ANSYS Meshing & Geometry | 1 | January 29, 2011 19:49 |
structured vs unstructured hexahedral meshes | Usman | FLUENT | 0 | January 19, 2008 04:20 |
Structure vs unstructured meshes | Des Aubery | Main CFD Forum | 2 | July 25, 2003 23:11 |
artifical dissipation on unstructured meshes | Frederic | Main CFD Forum | 0 | October 31, 2001 17:42 |
Higher Order FV Schemes for unstructured meshes | Apurva Shukla | Main CFD Forum | 4 | December 15, 2000 09:17 |
